Thank you
Thank you
Here are a few signs I cut out for two different people. Both were done on old reclaimed fence boards 1/2 thick used a 60 degree v-bit.
Attachment 256178
Attachment 256176
The sample cut for the VaCasa logo looks like they want a few boxes made with the logo.....time to get workin on the details.
nice write up!
Thanks most appreciated!
Here are a few pictures from a new advertisement kiosk I am working on for a client.
Attachment 267598
Attachment 267596
Attachment 267600
Attachment 267602
Attachment 267604
very nice design :cheers:
Got any links for the new rotary setup? Looks nice.
What happened with the old one? It looked like you had a lot of work in it, did it not work out as planned?
I purchased it from a source on the internet. Since the experience with them was less than professional I would prefer not to send anyone down that path. When I asked for paperwork on the stepper motor and the wiring specs after I bought it they were extremely rude and unprofessional. So for now everything has been guess work since I have no specs on motor. I have it plugged into my y-axis location and all spins well. I might purchase a stepper from CNCrouterparts and replace the one that came with it so at least I would know what I had and how to program it in Mach3. The gear reduction is 20:1 and the stepper motor is nema 34. I did find a tag on the side of the motor and tried looking it up on the net with no luck.
As for the other one I started on I still have a few more things to finish up on it to make it all work. Decided to go with a large industrial indexer since I have a few clients waiting on some custom bats.
Wow, This looks Awsome :-) Can you make a video of it in action?
Working on getting this thing going along the X-axis. Got everything wired up and turning. Now I just need to figure out how to configure it properly......I admit I do feel lost with this one, so i thought I might give the guys over at CNCRouterparts a call and see if they can talk me off the ledge.
Spoke with Cory at CNCrouterparts and he was able to give me a little instruction. So for this weekend I will attempt the following.
-Copy my current default xml file that I am using and rename to indexer
-Switch the A-xis to a B-axis that is slaved to the X-axis
-Y-axis will now be used by the indexer since I have the indexer parallel with the X-axis
-Design some text to be engraved on the a used bat in VCarvePro
-Save toolpath onto flashdrive
-Load it onto CNC computer in the garge
-Chuck up a used wooden bat in the unit
-Zero the Z-axis according to the instructions in VCarvePro
-Do a few test air cuts to see if it is on target
-Pray
-Then do the real thing!
Well I finally was able to cut a little on a used bat that I had sitting around. The first way was to mount the bat in a cradle that was fastened to the table and cut just like you were cutting a regular piece of wood by using the pocketing function in VcarvePro. Then I unplugged the Y-Axis and plugged the indexer in to the Y-Axis location and test a small engraved text area on the end of the bat. Everything seemed to work O.K. except the text was backwards and upside down. So I made a copy of the xml profile I was using and renamed it Indexer. Then I reopened the Mach3 program and reversed the setting for the Y-Axis and did another test cut. This time the text came out exactly the the designed file.
Attachment 273848
The next item on the list is to get the steps per degree sorted out. This might be a challenge, when I try to look up the information that is on the tag of the motor on the internet I get nothing. So I am guessing that someone in china has relabeled the motor and there are no specs available. If I cant get this figured out then I guess I will be purchasing another Nema 34 motor from the guys at CNCRouterParts.
Good Luck and continue on.. :-) :banana:
Finally built a few mounts for the front of the table to hold the rotary axis. Now I can use the full size of the table without the rotary axis getting in the way.
Attachment 274300
That's bad-ass. I have a rotary axis for the laser, and I would eventually like to get one for the router. The way you've set this up is pretty spectacular. Any hints on where you sourced the stuff?
How do you lock tailstock on that linear bearing
Here is a photo of the way it is locked down.
Attachment 274818
I am not sure if it is the right place to air out bad customer service. I normally would not suggest a vendor that had such poor customer service, however if you are really interested P.M. me and I will tell you who I bought from.....just warning you up front that your mileage may vary!
