Hi everybody,
I can not change the value of Pr01 (Servo loop type: STY) from speed (0001) to position type (0000).
I looked out the relevant in the manual:
Section 3.11 “these are validated when the power is cycled after setting”
Section 4.3 “defines whether the diriver is a position or speed type”
After set STY from “0001” to “0000”, then turn OFF and turn ON the power, the display is still “LP-V” and everything does not change.
Whether it fault or there are some settings else?
Thank you.
