Originally Posted by
jestalavita
Thankyou for all the info grawley, nuch appreciated. I think i have stumbled across the problem,i think its to do with water, and that the laser has been set up incorrectly i think cause it has 2 laser tubes but the inlet water and outlet are not in same ports(the 2 tubes are also connected by a tube, which I assume is wrong), I am assuming that they should be individual. There are 2 pumps with it but i think one is not doing anything. i cannot find a diagram on net with info on where the inlet, outlet and linking tubes are correctly labeled. Does anyone know if the double laser has same water running through both tubes in one cycle. To me this seems wrong. The manual is in broken english and i cant make sense of it.iI will try upload these photos and maybe someone can guide me as to which hoses go where. till then thanks all
