I discovered something interesting about Sprutcam last night. It involves using the 2-D contouring operation on a curve. I cut two identical parts which were cam profiles about 3" in diameter using what I thought were two identical tool paths. One came out with the very smooth curve I was expecting and one came out with fairly wide (about1/8") facets that approximated the curve and pretty much ruined the part. The simulation showed no difference in the machining results no matter what resolution I ran. After much trial and error adjusting settings, etc.,I realized that I had generated the two curves in two different ways. The first way was to select the face of the profile and then project it to the z-axis to generate the curve. This is what I normally do and it produces the smooth cutting result. The second way was to select the edge of the profile to generate the curve. This produced the ugly faceted result. My CAD software is SolidWorks if that means anything, and I always use the SW native format. The edge selection resulted in a single continuous curve and so there was nothing to join. I've read complaints from others about faceted cuts but this is the first time it has ever happened to me. The biggest problem is that the user doesn't see the problem until it is too late and the part is actually cut. I'm using the latest build of SC7. - Terry
