586,744 active members*
6,058 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Vertical Mill, Lathe Project Log > New Spindle Encoder Twice the Resolution of Old Encoder - What to do?
    Nov 2003
    We have a Romi D760 VMC. Recently, the spindle encoder went out causing a position coder disconnect error on the spindle amplifier. After troubleshooting, we ordered a new encoder from Heidenhaim using the part# in the Maintenance Manual for this machine. This newer version (ERN420) of the old encoder from Heidenhaim delivers 2048 PPR. The position coder disconnect error is gone; however, the speed shown on the Fanuc Operator Panel is about twice the actual spindle speed. Example: Operator enters an "S500 M03;" and the spindle actually turns at 500 RPM (hmmm, expecting the Spindle Screen (enclosed picture) to show 500, not 533RPM, since Gcode is "S500'); nevertheless, a photo-tachometer shows the spindle at 500 RPM and the Operator Panel shows the Spindle Speed at 1,000 RPM. Also M19 Spindle Orientation doesn't work (spindle keeps rotating at a couple of hundred rpm).
    Fanuc said to check Parameter 3706 [Position Coder Gear Ratio]. It's set at "x1", i.e. 00 and if we change it to x2, x4 or x8, the Speed showing on the Operator Panel simply continues to double from it's already-doubled showing. This is telling us that no matter what the Heidenhaim Encoder Model# shows in the manual (evidently this 2048 PPR model), the required spindle pulse coder should actually be 1,024 PPM, so the question: Is there a way to adjust parameters and make this higher resolution, incremental pulse coder work with this Fanuc 21i system or do we have to order a 1,024 version?
    Thanks!
    Ev
    Attached Thumbnails Attached Thumbnails NewSpindleEncodeVersusMotorSpeed01.jpg   NewSpindleEncoderPartNumber01.jpg
    Jan 2008
    1535
    Can you set the gear ratio to 0.5?
  1. Broken BridgePort Encoder, Need new encoder or ServoMotor w/Encoder
    By TNBG_LTD in forum Want To Buy...Need help!
    Last Post: 03-18-2020, 08:54 PM
  2. Encoder resolution too fine?
    By erikjgreen in forum Servo Motors / Drives
    Last Post: 03-18-2015, 02:46 AM
  3. Encoder CPR/Resolution... is 400 CPR good for 1:1
    By ngr1 in forum Servo Motors / Drives
    Last Post: 08-20-2005, 10:13 PM
  4. High Resolution Encoder Help
    By Donovan in forum Servo Motors / Drives
    Last Post: 02-13-2005, 04:05 PM
  5. High resolution encoder
    By ToyMaker in forum CNC Machine Related Electronics
    Last Post: 06-11-2003, 08:04 AM
