586,941 active members*
2,465 visitors online*
Hybrid View
    Oct 2010
    136
    Table mounted enclosure
    Built this based on the stock sheet metal, some MiSUMi extrusions, track and brackets and some polycarbonate panels. Tried to keep it light. Tested with a very busy four hour program and no rattles and so far nothing has fallen off. Got the sliding door idea from the enclosure I saw at Tormach this last Summer. But I thought I'd try a smaller enclosure before going nuts and building a big one.
    Note I also use nylon curtains that run on a track attached to the ceiling. They work great as a last catch for the wild stuff.
    Mar 2009
    1863
    I like it. Relatively inexpensive and very functional.
  1. Haas TM table enclosure
    By mtlhe in forum Haas Mills
    Last Post: 05-23-2013, 01:33 AM
  2. Power Draw Bar and Table Mounted Rack Tool Changer?
    By David Bord in forum Tormach Personal CNC Mill
    Last Post: 08-12-2010, 03:16 PM
  3. Nice enclosure plans / table for IH ?
    By Rich05 in forum Charter Oak Automation Support Forum
    Last Post: 07-08-2007, 02:03 AM
  4. Vertical mounted router table?
    By 307startup in forum DIY CNC Router Table Machines
    Last Post: 02-09-2007, 04:37 AM
