586,308 active members*
3,288 visitors online*
    Oct 2010
    23
    Help needed with thread cutting -G76
    One of my technicians is trying to single point thread a 1" - 32 thread 0n a Mori Seiki SL-1a with a LX1 Yasnac control.
    He is using g76 single line. G76 x-9617 Z-565 K.0191 D.003 F.0132 A60
    He keeps getting an 096 error code:
    D (cutting frequency) Specified by G73 zero or 128 or more.
    I,K (rough cutting) specified by G73 both zero
    D, K of G76 exceeding Programmable Range
    I have tried my best to work this out but it has been a couple of decades since I have worked with this machine.
    Can anyone help? I am about to toss it on the manual machine and single point it.
    Brian
    Oct 2010
    23
    Sorry that G76 line should read G76 X-.9617 Z-.565 K.0191 D.003 F.0132 A60
    Aug 2011
    2517
    try 2 lines....
    G76 P030060 Q0.003 R0.001 (in the P the first 2 numbers are the number of finish passes, 2nd 2 are chamfer amount at the end of the thread, last 2 numbers are the thread angle, Q=rough cut depth, R=finish amount)
    G76 X-0.9617 Z-0.565 R0 P0.0191 Q0.008 F0.0132 (R=taper, Q=first cut depth)
    2932
    I believe your D value is too small. Try D0.0033.
    According to the manual: 1/6 K ≤ D ≤ K
    K=0.0191
    K/6=0.0031
    D must be between 0.0031 and 0.0191 to satisfy above limit.
    Jun 2004
    236
    Bingo, Saw that right way!
    Quote Originally Posted by dcoupar View Post
    K=0.0191
    K/6=0.0031
    Visit our face book page, search on FaceBook; High-Desert-Precision-CNC-Machining-Nosalas-Hobby-Shop
  1. OD Thread Milling Help Needed...
    By 67Cuda in forum HURCO
    Last Post: 09-01-2013, 08:02 AM
  2. Help needed on 4 start thread
    By extanker59 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-20-2011, 04:05 PM
  3. Thread cutting
    By Roadster in forum Shopmaster/Shoptask
    Last Post: 10-15-2009, 08:05 PM
  4. NPT Thread Info Needed
    By NL2000 in forum MetalWork Discussion
    Last Post: 12-06-2006, 02:18 PM
  5. Thread Mill Cutter Help Needed
    By TZ250 in forum MetalWork Discussion
    Last Post: 10-05-2006, 06:40 AM
