586,655 active members*
2,829 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Power Supplies and drivers, what fuses and holders are you useing?
Results 1 to 3 of 3
    Jul 2012
    159
    I am putting together my power supply and the electrical enclosure. I have everything sorted but looking to see what fuses and fuse holders you guys are using in yours?
    My power supplies are torrid transformers so need to put a fuse on the input leg 115vac 20 amps
    One is 130vdc 18amps and one 60vdc 15 amps
    and then of course the drivers all are 60vdc 5 amps
    Thanks for the help
    Dec 2003
    24223
    I use the clip together DIN mount style with small cartridge fuses.
    Al.
    Albert E.
    Feb 2009
    6028
    I use the wago terminal block style fuse holders for the smaller ones like that, busman din for the larger amperage ones,
  1. Power supplies
    By ttarter3 in forum Stepper Motors / Drives
    Last Post: 01-06-2013, 06:01 AM
  2. Help sizing fuses for Gecko 320x drivers
    By Jackal66 in forum Gecko Drives
    Last Post: 05-30-2011, 12:26 AM
  3. KL- 7220 Power Supply Blowing Fuses
    By MRM RCModels in forum Automation Technology Products
    Last Post: 03-17-2009, 03:33 PM
  4. Fuses & drivers
    By mtompson in forum CNC Machine Related Electronics
    Last Post: 11-20-2007, 09:08 AM
  5. power supplies.
    By LeeWay in forum Gecko Drives
    Last Post: 05-19-2006, 11:17 AM
