I think it more boils down to what you plan to do with the machine. If you need to do heavy hogging out on steel all day long a big heavy mill is the ticket, but if you plan to do small cutter detail work in aluminum a smaller mill with a very high speed spindle will eat the big machine's lunch.
I know for which speak. I've got a Hurco KMB1 4HP (motor is actually 5HP) 3500 RPM machine, and a Taig with a 28000 rpm spindle. Those are about as far apart as you can get in mills, and yet they both do things well that the other one doesn't do very well.
... And then there is cost and time. I had my Taig up and running and cutting parts in a couple days. Mostly getting it figured out. It took me almost three years to retrofit the Hurco.
Bob La Londe
http://www.YumaBassMan.com
