586,357 active members*
3,370 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > pacific scientific true treadmill brushless servo drive pc2302-010 help
    Oct 2007
    13
    I recently got a 1920's or earlier Van Norman #10 duplex milling machine with no motor. So i got this free true 850ztx treadmill for the motor/controller. Its a 6hp 3200rpm brushless servo drive 320vdc. The controller is a pacific scientific model pc2302-010 Witch i cant seem to find any info on. The treadmill worked fine so I could use the big old display to control the motor speed if need be. But I would really like to have a led spindle rpm display with a Potentiometer to control speed. The controller has a 10 pin plug labeled j2 CMD I/O on the circuit board witch goes to a smaller board between the display and the controller. Then the obvious power terminals tb1 motor connections tb2 , speed sensor j1, then a four pin unused j3, and lastly a e1 10 pin unused. Any help would be appreciated. I have read a bit about 555 timers for a pwm signal but i am unsure what type of signal is required for the esc. Or if their is a simpler more economic solution. I could take some pictures if that would help. this is what it looks like though Used True Treadmill Motor Controller 825, 850, Z Models For Sale - Used Treadmills For Sale
    Feb 2016
    Re: pacific scientific true treadmill brushless servo drive pc2302-010 help
    Did you ever get any information on this drive? I have the motor and controller but nothing else and would like to use it to power my Lathe if I can find out what wiring is required to make it run.
  1. PACIFIC SCIENTIFIC
    By syeraven in forum CNC Machine Related Electronics
    Last Post: 09-24-2009, 02:00 AM
  2. Help needed with Pacific scientific sc320 drive and DPM
    By dannystooblue in forum Servo Motors / Drives
    Last Post: 06-13-2008, 06:07 PM
  3. Pacific Scientific R Servo Compatibility
    By kirk_wallace in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-25-2007, 12:48 PM
  4. Pacific Scientific 6510 Drive
    By marshall1 in forum Stepper Motors / Drives
    Last Post: 03-29-2006, 10:27 AM
