I am trying to understand how a linear actuator works. My application needs a fast moving actuator with very little load. The idea is to use the least amount of hardware and work as possible. The power source should be AC or DC (preferable DC). The travel should be limited which means either use 2 limit switches or use stepper motors with a controller.
Is there a linear actuator setup that does not need a stepper controller card?
