586,403 active members*
2,858 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Mini Lathe > HF 8x12 MOD (Stud mounted chuck.)
Results 1 to 8 of 8
    Oct 2003
    153
    I haven’t found any place on the net that has a lot of info about 8x12 mods, so I thought I would post mine here.
    While doing the initial cleaning, and busting my knuckles getting the chuck off, I decided my first mod would be making studs to mount the chuck.
    I made the studs by parting the heads of some 50mm hex head bolts, and then turning down the last 8mm, so that the bolts seated against the bottom of the holes (the holes are not tapped all the way to the bottom).
    Dan Sherman
    Aug 2005
    34
    Nice Mod! I think that one goes on the todo list after I get my QCTP mounted.
    Dec 2005
    82
    How is the check normally mounted on the 8x12? Your mod looks the same same as the how the chuck is mounted on the 7x12s. Just curious, because I have finally mastered the 7x12 three-finger-chuck-nut-change.
    mjarus.
    Oct 2003
    153
    Mjarus,
    From the factory, the chuck is mounted using 8mm socket head cap screws that fit into counter sunk holes on the back of the spindle face. The only way to get them out is with a shortened Allen wrench, a real knuckle buster.
    -Dan S.
    Dan Sherman
    Dec 2005
    82
    Unless there is quite a bit more clearance on the 8x12, I do not see how they would expect you to fish an allen wrench back there and get enough leverage. At first I thought the stud and nut of the 7x12 was a PITA, but that does sound worse.
    After you get used to the stud and nut approach it really isnt that bad, but when they come from the factroy the nuts are pretty frozen on the stud and it takes quite a bit of pressure to get them off. I lost quite a bit of skin on that battle.
    Would these have worked too?
    http://www.littlemachineshop.com/pro...ProductID=1222
    Either way, nicely done!
    mjarus.
    Oct 2003
    153
    Quote Originally Posted by mjarus
    mjarus.
    those paticular ones won't work, because the allen bolts are 8mx16. If i get a chance tonight i will take a photo of the ground down allen wrench need to get the bolts out.
    Dan Sherman
    Dec 2005
    82
    Sounds like you may have found a small cottage industry! LMS sells those kits for $2 and I am pretty sure that there are no more than $.50 worth of parts there. I ain't knocking them either... I bought a set for my 4 jaw chuck. I just did not feel like messing with it!
    Granted you probably would not get rich, but you have a good solution for what I am sure is an annoying problem. :cheers:
    mjarus.
    Oct 2003
    153
    As promised, a photo of an original bolt, and ground down Allen wrench.
    Dan Sherman
