587,040 active members*
2,723 visitors online*
Results 1 to 3 of 3
Threaded View
    Mar 2005
    266
    TAIG can be used horizontally!?
    I was trying to work out a way to drill holes in the end of "tall" parts. First thing to come into mind was that I could tilt the Z and drill at an angle using X,Z axis rather than just the Z but that also meant I would have to fix the part at the same angle. I took the spindle mount off and turned it sideways and voila I can use the X for drilling parts the only problem I can see with this is that the motor is hanging very far to one side. In the pic evertything looks a little crooked its not an illusion everything is I was just taking a quick pic...
