586,903 active members*
2,801 visitors online*
Thread: Sable 2015
    Dec 2008
    26
    Sable 2015
    Quick question on the Sable 2015 CNC Router Table.
    I bought one of these way back when, as it looked like a smoking deal. I've never used it, but it did get all setup. After stuff being moved around, the controller ended up on the powersupply.....still plugged in to a powerstrip. Long story short, smoke came out of the controller.
    So my question is, can I use a different controller...the ebay guy wants $100 plus $50 shipping for one. I see controller boards for $50, so was wondering which if any I could use to control this. I would like to convert to USB if possible.
    Later EddieO
    Aug 2015
    Re: Sable 2015
    Quote Originally Posted by EddieO View Post
    Later EddieO
    Necro Thread.
    I have one on the way and plan to use Arduino and GRBL to run it, similar to my 3020 I just converted. As long as the you have a 24 volt power supply, I am not sure if the power supply you have powers both the spindle and the drivers, I have a feeling that it would need to be separated due to the power needs the motors need.
    Anyways, here's a quick vid I did of the conversion, it'll be very very very close in the way I am going to do it, the math for the step/rev/per mm settings will be different.
    Metro Made | 3020 CNC Arduino GRBL Conversion - YouTube
  1. Sable-2015 collet
    By vph in forum Want To Buy...Need help!
    Last Post: 12-22-2010, 06:52 PM
  2. So I have this new Sable 2015
    By Bemsed in forum PCB milling
    Last Post: 11-07-2010, 08:33 PM
  3. Sable 2015 VS FireBall V90
    By PunKidd in forum Want To Buy...Need help!
    Last Post: 08-19-2010, 12:28 AM
  4. I bought a Sable 2015
    By gbrock113 in forum Signmaking Topics
    Last Post: 05-19-2010, 10:18 PM
