I am in the market for a lathe again, and I really want to do a CNC conversion as I just finished a mini mill (X2L) conversion, and I am quite fascinated with the potential for what CNC can do for me.
I am looking for some opinions on whether or not its worthwhile on a lathe.
My thought is if I am going to CNC a lathe, I am probably going to buy a Grizzly G0602, as it should be big enough for me, and I don't want to spend a lot of money on the lathe itself for the gearbox, only to not use it.
If I am not going to CNC the lathe, I will probably go with a full gearbox, something like a G4002 or G4003, or the g4003G the gunsmith version.
It seems like for a milling machine CNC, there is a ton of reasonable CAD software and toolpath generation software that make it really a no brainer for me at least.
However, I cannot seem to find much in the way of CAD or toolpath generation specific to the lathe, which makes me wonder if it is worthwhile doing a CNC lathe conversion.
I am not a good machinist, and machining is a means to an end for me to be able to do other things. I enjoy machining, but it is a very, very time consuming thing to do right, so, I don't envision ever being anything more than a competent machinist, which is why CNC is so attractive to me. I can design pretty well in CAD, and I can learn enough machining, or already know enough, to produce great parts without becoming an expert in machining.
Sorry for the ramble, just want to pull the trigger on a lathe, but want to work this out first. Any opinions would be great!
