586,640 active members*
2,775 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Thread Milling, Can you do this ?
Results 1 to 9 of 9
    Feb 2013
    26
    ok it has been put on my plate to repair a thread in a part that has a thread in it already. They want me to pick it up and rethread mill it i dont think this is possible and if it is i have no clue how. Any tips suggestions etc. please feel free to tell me where to start or why it can't be done.
    May 2003
    323
    I have done thread repairs on turning but not on milling.
    Creap up with the tool to the thread as close as possible and skim it just enough to see witch way you have to offset until you get full clean up on thread.
    Dykem the thread before cutting.
    Good luck
    Jan 2005
    15362
    heavenlykid
    I would say it would be a struggle to do it on a cnc mill, if the part has orientation as to how it was clamped/made when the thread was cut, then this would make it easier to do but still no a easy task, If you have a manual lathe, & the part can fit in a lathe, it is very easy to do
    Mactec54
    May 2004
    402
    Offer to bore it out and fit a Helicoil - probably a more reliable approach
    Andrew Mawson
    East Sussex, UK
    Mar 2006
    2712
    Ditto #4
    Dick Z
    DZASTR
    been there before and most times it's a dead simple fix
    you don't specify the diameter but I'm assuming that its too big to tap , so with that in mind , start by qualifying the hole center , move across one axis while the other stays in it's zero position , then eyeball till the threads mesh with the thread mill , then calculate a z start point accordingly . Patience is the key and a bit of blue can be helpful
    Otherwise ditto to the helicoil or insert
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
    Apr 2012
    43
    Use your offsets.
    Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
    Jun 2007
    87
    I would go with what derstap said. I will only add that you have to align the tool tip to center. you can do this by using an indicator and manually touch it to get the peak while manually rotating your spindle back and forth. then you can move the tool on 1 axis to position to align with the thread while the other axis is at 0. It could be a little tricky if the hole is blind and you don't have room to go beyond by at least 1 pitch, but you can also get the coordinates for the entry using trigonometry.
    Jun 2007
    3757
    A practice cut in a piece of hardwood will help give confidence the program is correct.
    Measure twice, cut once.
    Thread Milling Slideshow by neilw20_2008 | Photobucket
    or just the pictures..
    http://s399.photobucket.com/user/nei...?sort=6&page=1
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
  1. thread milling
    By bwarr001 in forum BobCad-Cam
    Last Post: 10-25-2012, 08:47 PM
  2. Thread milling
    By Bradosb in forum HURCO
    Last Post: 10-10-2012, 04:51 PM
  3. THREAD MILLING
    By woodzrider in forum MetalWork Discussion
    Last Post: 09-21-2011, 08:45 AM
  4. Thread Milling
    By mrsammy in forum Mastercam
    Last Post: 07-21-2010, 03:48 AM
  5. Thread milling
    By shake n bake in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-09-2009, 11:04 AM
