Originally Posted by
Flyer66
Hi doorknob thx for your reply
I'll try to connect my nema 17 with a 24v Ps, reduce the current dip setting to 25% and go up from there and see what happens.
About the shapeoko, do you feel that for some heavy duty work it needs a nema 23 or 2x nema 17 will do the work the same way , what is the configuration you are going to choose? 1 x nema 23 on X or 2x nema 17 on X axis?
BTW Are you going to use the (stock) belt drive or going to upgrade to guide racks ?
I'll also look a the Pololu A4988, I'll feel that If I'll have the shapeoko in the future the "weakest link" will be the TB6560...
Thanks,
