586,740 active members*
2,554 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Fadal Tool Change Position
    Feb 2013
    23
    Does anyone know if it is possible to change the location of the table for a tool change ?
    Feb 2005
    303
    Quote Originally Posted by BW4706 View Post
    Could you be a little more specific... Which machine/model/controller?
    iirc, our Fanuc-controlled mills could do a Z-straight-up change anywhere on the table, but the older Fadal-controlled machines had to go to the reference points first.
    Feb 2013
    23
    I have a Fadal VMC 15-XT. The control is a 88HS. The machine always moves to same position to do a tool change and I would like to know if and how I can make it move to a position I choose to do the tool change. I appreciate your help. Thanks
    Aug 2006
    52
    I use format 2, and my 88hs machine ('98 3016L) will tool change at the current table location -- it just goes up in Z and swaps tools.
    Jan 2013
    24
    Are you still needing an answer to this question? Or did you figure it out? I run 2 operations on the table at once with 9" tall parts, and 8" long tools on a Fadal 4020 with 20" Z travel and am programing in format 2. If you need, I'll send a sample of my program so you can see what I'm doing.
  1. How to change Tool change position(About MAZATROL T1 control)
    By liushuixingyun in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-07-2014, 01:33 AM
  2. tool change position
    By jschmid in forum Fanuc
    Last Post: 08-12-2013, 10:55 PM
  3. Fadal VMC 15 XT Tool Change Position
    By BW4706 in forum Fadal
    Last Post: 03-08-2013, 01:34 AM
  4. Setting tool offsets and tool change position.
    By trishbits in forum CamBam
    Last Post: 02-08-2013, 12:18 AM
  5. tool change position
    By miand in forum OKK
    Last Post: 09-28-2009, 02:02 PM
