HI
I am going to be starting a new 4x8 build soon, and i will be doing a welded steel base, what i am wanting to know is how far can i span the steel.
Here is a picture of the machine that i like the look of and that i will be making the base similar to, its a camaster stinger, if you look at the picture you can see that it only has 4 legs and so it has a span of roughly 3m from front to back, i am making my machine out of 100x100x6mm (4x4x1/4in) so i am wondering, would i get any flex in the middle or sagging? from having a gantry that will weigh in the ballpark of 120kg?
Attachment 199896
The reason i would like to do a similar design is so that i can put my motors and gearboxes underneath the machine instead of hanging off the side, so if i put legs half way down i wont be able to do that.
Chris
