1997 Dyna Myte DM2900 mini-mill (about 1500lbs, 2hp)
X and Y axis smooth as silk at 150ipm rapids
Z axis shudders on downward movement at 60ipm. Starts out smooth for about a second then vibbrrATTEEEEEEEE. Its not an earthquake or anything, but its definitely not good.
Per tech support I tightened the Z axis gib (s?). This style has one screw on top and one screw on the bottom of the spindle casting, and you loosen one, then tighten the other. The gib was definitely loose because the head would slowly fall during E stop. So I tightened it a bit. It fixed the head falling issue, but not the shuddering issue.
If you are jogging the head down at 60ipm, it starts smooth for about a second, then starts shuddering. If you let go of jog, then start it up again, the shudder is gone, then comes back, in the same way as when you started. Seems to be pretty much the same anywhere on the Z axis.
If you slow down to 40ipm, it doesnt seem to shudder anymore.
I guessed that maybe i hadnt tightned the gibs enough, or I had tightened them too much, so I played around with much tighter and much looser. Much tighter (a few turns) seems to cause consistent, heavier vibration. Much looser doesnt seem to change anything.
I had been using jack hydraulic oil for lube, but I finally got my hands on some vactra #2. I wasnt sure how long if would take to clear out the jack fluid, so i manually dribbled vactra 2 all over the z axis ways and ballscrew. It DID improve slightly! But its definitely still there.
If you push hard on the head so you are pushing it perpendicular to the Z axis, you can make the vibration go away. But only if you push very hard (as hard as possible).
The steel cart the mill is mounted in is on casters. Perhaps I should install the levelling feet? i will do that tomorrow. Any other ideas? Please help!
