586,500 active members*
2,778 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Prolight turning center mach 3 conversion
Page 4 of 4 234
Results 61 to 64 of 64
  1. #61
    Nov 2009
    4415
    Re: Prolight turning center mach 3 conversion
    This is the time to do your research. I dont think anyone here minds you asking away if you need help. Do use the search function as you become more familiar here. It is amazing what is already written.
    The reason I said pawl was because my machine already had that design. I would not rule out gang tooling either. It would be easier to set up, quick to change but more limited on travels per tool. You could also use a quick change tool post and create a library. Do manual changes on previously recorded tools.
  2. #62
    Feb 2010
    3447
    Well dug into the electronics a little bit more. The motor is a 1hp 8000 rpm dc motor, controlled by a minarik electric co speed controller. The steppers are 150oz/in superior electric slo-syn. Seems like everything is really high quality and done right. I was debating on selling it, but have changed my mind. I'm going to try and map out what I can and attempt to integrate what's already there instead of gutting good stuff. I'm getting my x3 finally up and running and purchased tools so it will be nice to compliment it with a similar sized lathe.
  3. #63
    Feb 2010
    3447
    Attachment 233316Attachment 233318Attachment 233320
    The silver cable exits out the rear. The power plugs into the wall, and the silver cable I'm assuming is the 0-10v signal cable to control the speed, and direction. There is a encoder on the wheel of the spindle also so I'm not sure if that outputs to Mach also, or if the speed controller handles all that.
  4. #64
    Apr 2011
    131
    This thread turned silent. I tried to PM diyengineer but his box is full.
Page 4 of 4 234
  1. Prolight 3000 turning center C-axis driver failure
    By Robert440 in forum Stepper Motors / Drives
    Last Post: 06-20-2019, 05:41 PM
  2. WTB: ProLight 3000 Turning Center
    By dmalicky in forum Benchtop Machines
    Last Post: 05-06-2014, 04:23 AM
  3. Prolight 3000 turning center (lathe)
    By closetgenious in forum Maintenance DIY Discussion
    Last Post: 02-07-2014, 06:05 PM
  4. Prolight Turning Center convert to mach 3?
    By diyengineer in forum Benchtop Machines
    Last Post: 09-05-2013, 12:58 PM
  5. Prolight 3000 turning center C-axis driver failure
    By Robert440 in forum CNC Machine Related Electronics
    Last Post: 09-10-2011, 03:05 AM
