Ok, I am running this BOB using mach 3. This is my first time building a CNC and I am starting from scratch.
After configuring the EStop, step and direction pins, and assigning the charge pump to pin 17, I hooked a logic analyzer up to the output pins.
I am consistently receiving Direction signal on Z, Y, and X axis. Either a logic High or Low. I am assuming this is correct. However on the Step Pins for each axis, I am only ever getting a logic High. It never varies at all.
I at first assumed it was part of the charge pump system, but now I have set the output of the Charge Pump in Mach 3 to pin 17, and the Pump LED on the BOB comes on. Even after doing this, the step outputs are the same. I cannot find any decent documentation on the BOB.
When I probe the serial port directly I do see a nice pulse on the step output, it is just not translating through the BOB.
Does anyone know how to get my output?
Help would be much appreciated.
Here is a link to the BOB:
KL-DB25RS 6 axis Breakout Board with Relay and Spindle control | Automation Technology Inc
