586,126 active members*
3,063 visitors online*
IndustryArena Forum > Manufacturing Processes > Safety Zone > Hand Polishing with CNC Lathe in Spindle Jog?
Results 1 to 8 of 8
    Sep 2013
    Is it an industry standard that it is acceptable to hand polish a rotating part inside a CNC machine while in MDI or Spindle Jog? Does OSHA have a publication or standard for this? Has anyone here operated a business or worked somewhere that an employee was injured or killed by doing so? Any help will be greatly appreciated.
    Sep 2007
    100
    I worked in a shop where a co worker lost a finger on a lathe.
    He had a part in the chuck that had a flanged face with bolt holes through the face.
    He was polishing the faces and lost the finger when it entered one of the holes.
    I would have used a 1-2-3 block wrapped with cloth backed abrasive to do the job safely.
    May 2003
    323
    First is the safety on machine disabled.
    Read the labels around the machine
    But we all do it anyway (Polishing)
    Sep 2013
    Quote Originally Posted by ChrisW View Post
    I know the machine manufacturers say not to in their user manuals and labels on the machines, but everyone does it, it's historic. Across the country there's no telling how manufactures polish parts while the machine is in a manual mode and turning. Is there a spec or procedure anywhere for doing this safely?
    May 2003
    323
    I talked to a guy who had osha training.
    It is in the books about polishing
    We understand it as the gray area of manufacturing.
    Sep 2013
    Do you have any idea where I could find some literature on this? I've beat google up and haven't had any luck on OSHA's website.
    Feb 2009
    6028
    I believe the OSHA standard will point to the ANSI standard. If machine is under a certain size, and has an automatic tool changing device ( turning center, milling center) then the spindle shall not rotate or be able to be rotated with the enclosure door open, or something close to that nature. It's not cut and dry, it has to do with size of the machine (large machines are exempt) and automatic tool changer, and a couple other minor things. I have the standards, just no time right now to look them up.
    Machine Tool Specific Standards
    May 2011
    20
    Is it acceptable? No.
    Is it dangerous? Certainly.
    Is it commonly done? All the time.
    I use a screwdriver to act as a surrogate finger so I can keep the meaty bits clear of the sharp and/or moving bits. Did so earlier today on my bench lathe in fact. And later on hurt myself with a drill press instead. :nono:
  1. Stop spindle by hand
    By rubberduck666 in forum Syil Products
    Last Post: 08-25-2011, 07:10 PM
  2. Lathe Hand - MI
    By MachiningJobs in forum Employment Opportunity
    Last Post: 04-04-2011, 10:54 PM
  3. Want to Buy Second Hand CNC Lathe
    By sphulkar in forum Want To Buy...Need help!
    Last Post: 02-12-2011, 06:33 PM
  4. Newb Lathe question - accuracy by hand?
    By Rich05 in forum MetalWork Discussion
    Last Post: 09-02-2008, 05:47 PM
