586,991 active members*
2,703 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Clunking noise on all steppers
    Sep 2011
    94
    Hello I am having trouble with a clunking noise on all my steppers at any speed, I have not changed any of the settings and not had any problems for 2 years, I am using an xp box so I dont think it has to do with my bios settings, Also I have tried plugging my power supply into the wall outlet directly bypassing the surge protector with no luck
    some things I have noticed is that my monitor is sometimes fuzzy whether it is plugged in direct or through the protector, the indicator lights on the breakout board are bright except the ones that light when jogging which are visible but dim.
    My unregulated power supply is running about 160v according to my multimeter is this within spec? thanks for your help!
    Sep 2011
    94
    Quote Originally Posted by poorfarmer25 View Post
    update- I have tried running everything through a ups I borrowed off another computer, It worked for several minutes then it started clunking again
    Aug 2005
    18
    The reservoir capacitor in the unregulated power supply may have dried out due to heating.
    Sep 2011
    94
    Think I figured it out replaced my computer with another and have not had any problems.
    1695
    The problem might just be due the software that got installed on the "bad" computer. A clean installation might fix it.
    Sep 2011
    94
    A large part of the problem was my usb wireless adapter. I'll keep the old machine for a backup, but everything seems to be running good now. THANKS CNCZONE!
  1. Steppers run hot and make clunk noise
    By rkbuild in forum Benchtop Machines
    Last Post: 11-25-2012, 11:01 PM
  2. "Clunking" stepper motors with Windows 7
    By SpacedCowboy in forum Mach Software (ArtSoft software)
    Last Post: 02-11-2012, 10:25 PM
  3. Screeching Steppers Harmonic/Noise Reduction
    By catabolic in forum Stepper Motors / Drives
    Last Post: 07-13-2011, 01:51 AM
  4. Chinese eBay Steppers (Valued Steppers?)
    By emerz in forum Servo Motors / Drives
    Last Post: 04-08-2011, 03:28 AM
  5. Steppers Clunking every second
    By Brandocnc in forum Machines running Mach Software
    Last Post: 08-05-2008, 06:06 PM
