586,138 active members*
3,587 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Have trouble lofting a hex into a circle.
Results 1 to 20 of 20
    Apr 2008
    87
    Greetings. I am new to working with solids so this has been killing me. I am trying to create a 12.125 octagon that extrudes up .75 then lofts into a circle with the over all height being 2.9. I have tried a few different approaches and none seem to work the way I want. Can some one give me a pointer or two on how to accomplish this.
    Thanks for reading.
    Oct 2006
    104
    What is the diameter of the circle?
    Apr 2008
    87
    Sorry, should of included that. It is 4.45 I will post the results that I have in a few minutes.
    May 2007
    35
    I'm not sure if the same rules hold in mastercam so forgive me if this is incorrect.
    Other software requires that the two end shapes have the same number of segments/vertices in order to loft properly. You might try making the circle into 6 segments with the vertices aligned the way you want with the hex.
    Hope that helps.
    Sent from my SAMSUNG-SGH-I717 using Tapatalk 4
    Apr 2008
    87
    i will give it a shot, thanks!
    Apr 2008
    87
    These are the results I get. I noticed I said hex in my first post, it is an octagon. This is not what I am looking for. I basically want the flat on each side of the octagon to go straight to circle, not spiral.
    Attachment 198472
    May 2007
    35
    Played around a bit. I think the trouble is that you need to rotate the segments so they are lined up as you want. (I rotated 22.5 deg)
    You must also select the same sides on both the octagon and circle. (Ex. Top segment on the octagon and top arc on the circle)
    Apr 2003
    3578
    What version of MC or do you just want a STP file. I made mine in X7
    Cadcam
    Apr 2008
    87
    This is what I have so far. I am unable to get a full circle on the top. What I did was basically make a cone and then flattened the top, I was going to try and add fillets to get the circle, but that doesn't seem to work. I am currently using X5.
    Attachment 199010
    Apr 2003
    3578
    I used loft and extrude add a boss to create it. what size is the dia at top is that a 4.45 radii or Dia.
    Cadcam
    Apr 2008
    87
    It is 4.45 Dia. I am going to start over and play some more to see if I can get it.
    Apr 2003
    3578
    What size are the corner radii?
    Cadcam
    Apr 2008
    87
    The corner radii aren't critical really. I am trying to replicate this. It isn't for a job or anything. I am just finding things to try and make models of and I figured this would be kind of tricky.
    Apr 2003
    3578
    ok so we just guessing at the Radii then from it pictorially?
    Cadcam
    Apr 2008
    87
    That's all I was doing. I was primarily focusing on getting the draft to work for now. For some reason I am really struggling with it.
    Apr 2003
    3578
    PM me how to contact you I can help you off here.
    Cadcam
    Apr 2008
    87
    Thanks! I tried to PM you but it said you can't receive messages
    Apr 2003
    3578
    go to Home and call the number.
    Cadcam
    Apr 2008
    87
    Thanks for all the help!
    Apr 2003
    3578
    glad to be of help. keep plugging away sir.
    Cadcam
  1. Whens a circle not a circle
    By Rickyg in forum Mach Lathe
    Last Post: 06-11-2013, 06:34 PM
  2. write gcode for circle with 4 small circle inside it
    By Farzaneh_2010 in forum G-Code Programing
    Last Post: 12-13-2010, 05:24 PM
  3. Circle Help Trouble getting the right code.
    By ibuildstuff4u in forum G-Code Programing
    Last Post: 12-29-2009, 04:49 PM
  4. Lofting is killing me
    By CuttersCov in forum Solidworks
    Last Post: 04-12-2009, 10:00 PM
  5. Does TurboCAD Deluxe V14 offer lofting?
    By SteveC68 in forum Uncategorised CAM Discussion
    Last Post: 11-27-2007, 05:15 AM
