587,167 active members*
3,498 visitors online*
    Aug 2013
    G Code Programming Question
    Hi Everyone,
    I am looking for some help. I am moving an XYZ table with Mach3. I am trying to make a G Code Program for a specific application and haven't had any luck.
    I am moving the tool to some coordinates on X,Y and Z away from home. Then I make some movements on Y. Then the issue....I want the program to wait so I can jog and position somewhere else, then somehow press a button and continue running the program with these new coordinates that I Jogged to. Is there any way to do this?
    Go Home (OK)
    Move X and Y and Z to a certain position (OK)
    Use tool (OK)
    Move +Y (OK)
    Use Tool (OK)
    Move +Y (OK)
    Use Tool (OK)
    Move +Y (OK)
    Wait and let me jog on X Y Z manually (?)
    Save the new Y coordinate (?)
    Press 'Ok' (?)
    Use Tool (?)
    Move -Y (?)
    Use Tool (?)
    Move -Y
    Use Tool (?)
    Move -Y (?)
    I hope I am not too confusing. As always, thank you everyone for your help which is appreciated in advanced!
    Nov 2012
    33
    Did you try changing to Incremental motion mode? That way your cnc moves will be relative to the current position, not the home position.
    Jim
  1. Help! need someone to help w/ some mach 3 g code programming
    By sconklin in forum Mach Wizards, Macros, & Addons
    Last Post: 07-01-2010, 01:53 AM
  2. questions about g-code programming
    By grf in forum G-Code Programing
    Last Post: 12-04-2009, 09:00 PM
  3. M-code programming on Fagor CNC
    By aventure in forum G-Code Programing
    Last Post: 10-13-2008, 03:53 AM
  4. learning G code programming
    By ldaniels in forum Mach Wizards, Macros, & Addons
    Last Post: 05-08-2007, 07:47 PM
