Hi, I am looking to make paper lanterns with laser cut designs on them using quality white art paper. As only paper, they work well but I would like to fortify the paper somehow to make it more of a permanent home decor product instead of something so fragile that it may only be used once and thrown away. I have tried to stick paper to a thin plastic backing but bonding the two materials causes them to warp. The paper by itself lets out enough light for a good effect and the plastic alone lets out too much light through it (and the plastic looks cheap and doesnt cut the details like the paper does.) I know this is a difficult case and not really a laser cutting question. I cant use any kind of laquer on the paper cause its flammable around a candle and this is a lantern with a candle. If I put two different materials together, would it be better to laser cut them separately and then attach in some way after (not by glue but another method)? Any suggestions on what kind of materials I could try that would make the paper less fragile would be greatly appreciated.
Cheers,
Glenn
