587,040 active members*
2,928 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Need Help Making Connections With Haoyu TB6600 and a Sainsmart Breakout
Results 1 to 8 of 8
    Mar 2013
    32
    Hi, I have a 5 axis Sainsmart breakout board and would like to wire it to my haoyu tb6600 stepper driver. But I'm new to this setup and I am not sure how to make the connections. I mainly do not understand how to wire up the CLK+, CLK-, DIR+, DIR-, EN+ and EN-. Any help would be appreciated and I will post links to the products i have below for reference.
    SainSmart 5 Axis Breakout Board for Stepper Motor Driver CNC Mill*Blue* SainSmart
    TB6600 1 axis Stepper Motor 2-phase Driver Board for CNC Router [HY-TB6600-Module] - US $20.00 : HAOYU Electronics : Make Engineers Job Easier
    Feb 2007
    4553
    Quote Originally Posted by nlh205 View Post
    nlh205
    This should help,
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Mar 2013
    32
    Thanks for the response Jeff. But i have figured it out but the motor is just staying energized and squeezing. Thanks.
    Aug 2005
    18
    This driver is quirky in that you need to apply 5V across the enable opto isolator to disable it.
    Mar 2013
    32
    Thanks. I applied the voltage and it stopped the motor forming being energized but there is still no control from the pc. I have CLK+ gone to pin 2, DIR+ gone to pin 3, CLK- and DIR- together and gone to pin 14. In Mach3 I have the x axis set up from pin 2 and pin 3 AND then pin 14 setup to the x axis enable. Does these connections seem right? Thanks.
    Aug 2005
    18
    Leave EN disconnected for the moment - its only purpose is to turn the driver off.
    But you'll need to connect CLK-, DIR- to ground (0V) not to pin 14.
    Mar 2013
    32
    So it's been awhile since I have been at my cnc. But i'm back at it and still having some trouble. I have a mach3 system and i know its working correctly because i have tested it with the meter and all actions seem fine. So that shouldn't be a problem. I have a 13.8V power supply for the motors and I will post a link to the motors I have below. I will also post a image of the wiring. So the right to the problem, Lol. I only have once axis setup and testing and when I jog in mach3 the run light on the haoyu tb6600 will turn green, but no motor movement. I have tried it with EN+, EN- left out and also with 5V applied. Still no movement. Any thoughts would be appreciated. Thank You.
    Attachment 228582
    Nema 17 Motor:https://solarbotics.com/product/33600/
    Other component links are already posted in this thread.
    Jan 2012
    Re: Need Help Making Connections With Haoyu TB6600 and a Sainsmart Breakout
    I am just testing the Haoyu driver in my test environment.
    My wiring is comparable to yours, besides that I am using an Arduino running GRBL attached via USB at my laptop.
    This is just for testing purposes to verify that the driver works as expected.
    So I have attached Arduino GND to STEP- and DIR- connected Arduino DIR+ to DIR+ and Arduino STEP+ to CLK+ on the TB6564 driver board. First I had also wired EN- to Arduino Ground. But it was no difference, if any of the EN are connected or not.
    As soon as the driver is powered up (33V on my variable regulated power supply) it drives some current to the motor to give it initial holding torque. Then I send some jogging pulses to the driver via GRBL Panel software and the motor turns. Currently I am testing the right settings as the motor sometimes turns the wrong way round. Seems to be an issue with the right pulse and delay width, acceleration, max speed etc.
    As it is the first time dealing with GRBL, I am still in trial and error mode ;-).
    But the motor has initial torque (Nema 17, 33 V, draws 130 mA while not getting steps and around 600-800 mA turning at high speed). I am testing with 1/4 microstepping and current limited on the board to 1.2 A.
    Maybe that helps?
  1. Haoyu TB6600
    By bobgrant in forum Stepper Motors / Drives
    Last Post: 03-20-2018, 04:57 PM
  2. Haoyu tb6600 problem
    By prana7 in forum Stepper Motors / Drives
    Last Post: 08-11-2013, 12:52 AM
  3. SainSmart ST330 driver with TB6560
    By rinthesun in forum Stepper Motors / Drives
    Last Post: 06-09-2013, 02:42 PM
  4. 5 Axis Breakout Board + Drivers + Motor Connections
    By samsagaz in forum Stepper Motors / Drives
    Last Post: 01-11-2013, 01:59 AM
  5. Sainsmart ST330 (TB6560) Driver, does anyone know this?
    By a1579 in forum CNC Machine Related Electronics
    Last Post: 08-09-2012, 01:50 AM
