586,941 active members*
2,662 visitors online*
    Oct 2009
    LinuxCNC, DQ542MA driver and DB25-1205 BOB
    Hope this can help somebody in the future...
    LinuxCNC, DQ542MA drivers and DB25-1205 BoB (from Wantai Motors)
    When setting this up I had problems to find examples so I thought I might share what worked for me.
    Based on this image I found while searching I did the wiring (not mine picture).
    http://img195.imageshack.us/img195/9451/sitemanuevo.jpg
    The third red form the top that goes to ENBL + is connected to pin 16.
    Dip switches on the driver card are set for 200 steps/rev and 1/8 microsteps
    In LinuxCNC config I set:
    Driver timing: According to what is documented here LinuxCNC Documentation Wiki: Stepper Drive Timing
    Parallel port setup:
    Pin 2 - XStep
    Pin 3 - XDirection
    Pin 16 - Amplifier Enable (I will connect all drivers "ENBL+" to this pin. This will be a three axis setup for a mill)
    X Axis Setup.
    Motor steps revolution : 200
    Drivers Microstepping: 8
    Anders
    Spånga, Sweden
    Nov 2015
    Re: LinuxCNC, DQ542MA driver and DB25-1205 BOB
    The link above is dead.. was able to find it within google cache.
    attaching below:
    Attachment 298784
  1. Replies: 25
    Last Post: 02-18-2017, 01:02 AM
  2. Help Please - Driver Setup - LinuxCNC
    By CNC pupil in forum LinuxCNC (formerly EMC2)
    Last Post: 09-08-2014, 12:37 AM
  3. Replies: 4
    Last Post: 03-01-2013, 07:19 AM
  4. Stepper Driver 4.2A DQ542MA or PM542
    By kunte in forum DeskCNC Controller Board
    Last Post: 06-16-2011, 11:35 AM
