586,659 active members*
3,612 visitors online*
    Jun 2013
    1041
    Ssr to k-flop
    Does anyone know how I can connect a solid state relay to k-flop. I think I'm good with the 110v connection to the relay. I don't have a clue what to do on the dc side. The relay can drive up to 40 amps. It is a 3-30v input. The dc side has two screw terminals one is + and the other is -.
    I will be using it to turn a spindle on and off. I need to know what to hook to the + and -.
    Ben
    May 2006
    4047
    Hi Ben,
    It should be very simple. Connect a KFLOP IO on JP7 to the + input and GND to the - input. To test functionality use the KMotion.exe Digital IO Screen, set the IO as an output, and toggle the state.
    Regards
  1. Replies: 3
    Last Post: 07-27-2010, 08:47 PM
  2. G251 motor direction flip-flop
    By alphamail in forum Gecko Drives
    Last Post: 12-22-2008, 11:41 AM
  3. bistable flip flop
    By owhite in forum CNC Machine Related Electronics
    Last Post: 05-23-2004, 03:21 PM
