586,700 active members*
3,134 visitors online*
    Oct 2010
    62
    Slot cutting tool needed
    I am using a 3 axis milling machine and I need to cut a groove that is essentially an undercut. Therefore I need a tool that is profiled to the right shape to create this groove.
    The slot I need to create is quite small. Where can I get very small/fine slot cutting tools?
    Jack
    Oct 2010
    62
    I have made a drawing of the kind of cutter I have in mind. There are 2 pages to the PDF. The second page shows a rounded cutting area. This is preferable.
    Attached Thumbnails Attached Thumbnails Slot cutting requirements.PDF
  1. Cutting a slot in a shaft
    By Mogzieno1 in forum Solidworks
    Last Post: 11-18-2008, 07:59 PM
  2. cutting a slot with a t-slot cutter
    By cncuser1 in forum Mastercam
    Last Post: 09-10-2008, 03:02 AM
  3. cutting a slot
    By adamchapman in forum Mastercam
    Last Post: 08-21-2008, 09:40 PM
  4. T slot tool post with drill bit tool holder
    By brucesu1 in forum CNC Tooling
    Last Post: 06-09-2008, 11:04 AM
  5. powermill and slot cutting with woodruff tool
    By krustykrab in forum Uncategorised CAM Discussion
    Last Post: 02-23-2006, 11:25 AM
