I have everthing hooked up (I think right) but I can't get the servo motors tuned in very good. When I do get them close they will sing in one direction (most of the time) and hum I the other direction.
The motors are 600 oz\in peak Ametek
The power supply is giving out 56v @ I am not sure how may amps
Gecko 340 drives
Us Digital e2 500 ppr encoders
More on the power supply
The power supply is a toroidal transformer by Antek, I can't find any info about it on the web. It has two primary coils hooked up in parallel (?) and two secondary coils in parallel run hooked up to a birdge rectifier and two capatictors. The only markings on the coil are:
model# 7235 Antek
i/p 0-115 v
i/p 0-115 v
o/p 0-35 v
o/p 0-35 v
The only problem with the poser supply is it will throw a 20 amp 120 volt breaker on a regular basis.
What could be the problem? I have worked with it endlessly.
