New 2me 1987 VMC40 Axis Fault
I am hoping someone here can help me with some trouble shooting. I recently got a 1987 Fadal VMC40. The guy I got it from bought it from the place he worked to start making parts on the side but could not get three phase at the house and finally decided to get rid of it. It was a working machine when he bought it. The machine was in a guys garage for about a year I think, and he had removed the Z axis servo to get it through the door. When I got it to my shop I re installed the servo and wired it up. I powered it up and entered 2 for the pulley set up. The next screen tells me to jog to Home positions and then enter CS (cold start command) so I press the JOG button on the keyboard. It momentarily displays "JZ" and then "Amplifier Fault on Axis Z". I swapped what I think is the X and Z axis amps by moving all the wires on the two outside amps but I get the exact same error. I then reconnected the drives the original way and removed the power (black and red) wires that go to the Z axis servo and tried again only to get the same error. It is peculiar to me that it faults on the axis that the motor was removed. But it seems that the controller stops there and for all I know the controller has not checked the X or Y amp and I may get the same error there once I move pass the Z Axis Fault error.
The Fault lamp on the drive is not lit up and I am wondering how else to trouble shoot this before I start throwing money at parts to find out which one is bad. Any ideas here? Has anyone else had a similar problem?
So many projects, so little time...
