586,756 active members*
8,071 visitors online*
IndustryArena Forum > CAD Software > Autodesk > Autocad 2000 Move
    476
    Autocad 2000 Move
    I have a flat plate with a bunch of holes that I drew in AutoCad 2000. I then dimensioned all the hole locations. How do I get the dimensions to change when I move a hole location. When I do a MOVE command the hole location moves, but the dimension text stay the same.
    Vince
    24223
    There may be other ways but if you click on the dim marks and enable the GRIPS click on the end one and EXTend it to the centre of the moved hole. The dims will be updated to the new position.
    Al.
    If the dimensions are in modelspace, use the stretch command instead of move. Then you can drag the dimension with it. If the dimensions are in paper space, you're out of luck unless you use 2002 or later.
    Jan 2006
    Self updating dimensions
    When you 'move' the hole or other feature, select the geometry from top right to bottom left and that will move the vertices of each piece of geometry. Be sure to get the grip locations of the dimensions as well. This always works with me. One other thing...make sure that you have associative dimensioning turned on. I have actually worked with folks that thought the dimensions were better unassociated with the geometry. Good luck. Dennymac
    Jan 2007
    92
    Re: Autocad 2000 Move
    Try using DIMASO ON command in AutoCAD. That is supposed to associate the dimensions with the objects and update the dimension when the objects are moved.
  1. autocad 2000 an 64 bit
    By Holmes_ca in forum Uncategorised CAD Discussion
    Last Post: 09-26-2012, 08:26 PM
  2. Autocad 2000 help!!
    By dan327 in forum Autodesk
    Last Post: 02-16-2012, 03:30 PM
  3. Help: Autocad 2000 (Autocad Error aborting)
    By Holmes_ca in forum Autodesk
    Last Post: 05-07-2010, 02:07 PM
  4. AutoCAD 2000 to AutoCAD LT 2010?
    By 2kjettaguy in forum Autodesk
    Last Post: 08-15-2009, 03:33 PM
  5. Importing 3D from AutoCAD 2000
    By noisillator in forum Uncategorised CAM Discussion
    Last Post: 06-19-2009, 03:44 AM
