586,664 active members*
5,444 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Lathe > Help chosing a spindle speed sensor to indicate spindle speed in mach3
    Jul 2011
    I recently acquired a D&M 5 lathe. I used the thread http://www.cnczone.com/forums/bencht...m_5_lathe.html to overhaul the machine. I used a varipak controller and the G540, as well as some new steppers from hobbyCNC. I have managed to get the X and Z working and I can turn the spindle on and off, in Mach3, however I am having issues with the VFD, although that is not my main concern.
    I am looking to purchase a new infrared sensor, to use as a spindle speed sensor as the old one is not working. However I am completely new to these sensors and I have no idea which one to chose. My goal is to connect it to mach3 so that I can have an accurate spindle speed, in the program. I have a supply voltage of just under 20V so I was wondering if the one below would work:
    Here
    This is my first thread in this forum, so I am not sure if this is the best place to post this thread.
    24223
    That should work OK, If you are using the 20v for the emitter side your need around a 750ohm in series, if you are outputting the detector to a 5v input you need around a 2.2k pull up resistor.
    Al.
  1. mach3 spindle dro not working, spindle speed changing while jogging and running code
    By jasminder in forum Mach Software (ArtSoft software)
    Last Post: 02-23-2011, 07:12 AM
  2. X2 Spindle Speed Proximity Sensor Placement
    By Steoh in forum Benchtop Machines
    Last Post: 01-28-2011, 08:48 PM
  3. Replies: 6
    Last Post: 01-24-2011, 06:18 PM
  4. spindle speed sensor
    By escowizard in forum Bridgeport / Hardinge Mills
    Last Post: 08-22-2009, 04:09 AM
  5. Installation of spindle speed sensor
    By Bloy2004 in forum CNC Machine Related Electronics
    Last Post: 01-28-2004, 04:50 AM
