Originally Posted by
Dylwad
Even the best paint will fail with bad prep, but using the wrong paint with the best prep isn't any better.
I have used por 15 a lot in the past, it's a single component brush on paint that when cured is impervious to pretty much everything but the sun and sandpaper, but it's only as good as the prep, and needs to be applied to degreased and treated bare metal, sandblasting isn't required, not is removing every last trace of rust. They sell small kits that would be perfect for coating a machine, and it includes the degreaser and metal etch solution. It can be used inside of a gas tank if that's any indication of it's chemical stability, and is a pain to sand after it's cured.
Just a thought, I haven't ever heard of it on here being used to coat a machine, but I think it would be perfect, and they have UV stable topcoats for it if your worried about sun exposure or discoloring over time.
Sent from tapatalk
