Originally Posted by
BAMCNC.COM
Before tearing into anything the 1st step is to ohm out the probe. If you get a high reading you have found the issue(depends on probe setup)
Next would be tear apart and find out why, to much grease, maybe coolant, dirt, or spring screwed up?
You can get di-electric grease at any auto parts store, but its quite thick and if the spring can't push through it then its a bad idea, I personally use "EML" for all electrical contacts. It's a light di-electric oil, not grease. Grease is not the correct application for a probe, especially a "cheap" probe, you would be better off with WD-40....
