586,406 active members*
2,746 visitors online*
    May 2012
    13
    2x a strip with 5x .036 holes with precise spacing
    I am looking to have two of these produced.
    The holes are all the way through and .036" (+- 0.0005) (#64 drill).
    Holes are spaced 0.986" (+- 0.003) apart
    Holes are 0.300" (+- 0.010) from the long side and the first hole is 0.800 (+- 0.010)from the short side.
    I am aware that the holes are not perfectly spaced on the length.
    Each item:
    Length: 6" (+- 0.125)
    Width: 1"
    Thickness: 0.375 (3/8)
    This should be readily available sizes that just need to be cut to the right length, so it's just drilling holes in the right position.
    Material:
    Aluminum would be preferred, but teflon, deldrin or ptfe would also be acceptable.
    Shipping would be to Pasadena, California
    Attachment 193212
    Attachment 193214
    May 2012
    13
    Job has been given to a forum member.
    Thread can be closed.
    Jacksonqin0305 Guest
    Re: 2x a strip with 5x .036 holes with precise spacing
    Hey,guys,this is Jackson, mechanical manufacturing engineer with extensive field knowledge and work experience, my factory located in the world manufacture base center Dongguan/Shenzhen,China,your consultance of fabrication field of here always welcome,by the way,we offer Lathe and Milling/sheet metal fab/parts stamping service, any in need,
    Just contact me,[email protected],thanks
  1. A0 plotter Strip down
    By oshb5 in forum Benchtop Machines
    Last Post: 10-12-2010, 12:27 AM
  2. To Strip or not to Strip ?
    By Tonyr in forum Benchtop Machines
    Last Post: 08-12-2010, 08:07 PM
  3. X Axis Gib Strip
    By digitalmdj in forum Shopmaster/Shoptask
    Last Post: 04-13-2008, 04:31 PM
  4. Windows Strip Down
    By Me2 in forum Uncategorised CAM Discussion
    Last Post: 01-12-2007, 06:36 AM
  5. Drilling Precise Holes on Ridged Al. Angle
    By js530 in forum MetalWork Discussion
    Last Post: 06-09-2005, 04:26 AM
