586,617 active members*
2,429 visitors online*
IndustryArena Forum > CAM Software > Mastercam > 3D Surface Machining
    Feb 2012
    40
    Hello All,
    I need to machine a part with a slot whose wall is sloped at angle.
    For this slot(through hole), I tried a few Surface Finish Finish methods(Surface Finish Contour, Surface Finish Parallel Steep) on the MasterCam X5.
    It seems to me that each is good in an area but not finishing up the whole slopes.
    I attached a file so you could take a look at it if you would. The tool should not touch outside the slot window since there's
    material around the window.
    Which method would be best in this case?
    Thanks so much in advance,
    Ken
    May 2012
    180
    something like that i would use surface finish - constant scallop. only have containment on outer chain.
    i am running x7 so cannot save something for you to use, but the toolpath setting are quite simple.
    Feb 2012
    40
    Tried that and looks like it works much better. Thanks a lot!
  1. Machining a powder coated surface
    By rwskinner in forum Benchtop Machines
    Last Post: 12-05-2012, 07:41 AM
  2. Machining only one 3D surface?
    By patdttr225 in forum BobCad-Cam
    Last Post: 08-17-2011, 06:29 AM
  3. .stl surface machining question
    By bossdogg in forum Mastercam
    Last Post: 12-08-2009, 02:59 PM
  4. Surface machining advice
    By Julian M in forum Mastercam
    Last Post: 01-26-2007, 09:19 PM
  5. surface machining + xilog
    By Shawnm in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-18-2006, 02:55 AM
