586,780 active members*
3,369 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > 4 Axis Programming with BobCAD V25 4 Axis Pro
Results 1 to 11 of 11
    Mar 2012
    1570
    This video walks through a quick sample using the V25 Multi axis software. Take a look and let me know what questions you guys have...
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    15362
    alvdepoalo
    Looks great, keep the video's coming, users could benefit from you doing this, does it do simultaneous in 4 axes
    Mactec54
    Mar 2012
    1570
    Yes this part was programmed in true 4 axis....
    Al DePoalo
    Feb 2009
    2143
    Sweet!
    Could you do a "simple" 5-axis path/part as well (or link it if it exists already)?
    CAD, CAM, Scanning, Modelling, Machining and more. http://www.mcpii.com/3dservices.html
    Mar 2012
    1570
    5 axis machine setup
    Al DePoalo
    Mar 2012
    1570
    So I did a quick video using morph between 2 curves for a 5 axis part. It's a simple sample, but mcphill if you have a sample part you would like me to go though for everyone please share...
    Al DePoalo
    Dec 2008
    4548
    Here's a part I would like to see.
    I was thinking that "tilt lines" could be used to machine this with a head that rotated to allow the step down cut of the undercut?
    So, a head tilting with a stationary table cutting this would help me understand some stuff...
    Mar 2012
    1570
    Burr,
    Can you give me more information....
    How is the rotation going to be handled?
    Al DePoalo
    Mar 2012
    1570
    Something like this? ( no tilt lines used )
    Attachment 194040
    Attachment 194042
    Al DePoalo
    Mar 2012
    1570
    Hmm a new dialog box to learn!
    Al DePoalo
    Dec 2008
    4548
    Damn.. The smart dialogues!
    Yes, that cut is what I was refering to. I was looking at "tilt lines" more as a means to learn to explicitly cut the part... In other words, if I can force it to tilt and cut where I want, then the dialogues are easy....
    Probably my biggest stumbling block is I dont have/run a 5 axis machine, so I figure if I start with manually controlling the single added axis, then the rest will fall into place... I could be wrong
  1. BobCAD V25 4-Axis users. Go 4-axis Pro?
    By TonyW in forum BobCad-Cam
    Last Post: 01-05-2013, 04:30 AM
  2. 5 AXIS PROGRAMMING
    By SOLIDCAMSTEVE in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 12-15-2011, 11:53 AM
  3. Help with C-axis programming on 18i-TB
    By Adaware in forum Fanuc
    Last Post: 06-28-2011, 10:41 PM
  4. Need help in 4 axis programming
    By johan2008 in forum Mastercam
    Last Post: 05-02-2008, 03:03 AM
  5. 4-axis, 3+2, or 4+ axis programming system?
    By roboticist in forum Uncategorised CAM Discussion
    Last Post: 09-04-2006, 07:02 PM
