587,035 active members*
3,186 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > okuma lr 15m osp 5020l
    Feb 2013
    Question okuma lr 15m osp 5020l
    hi all if I send a program via pc or edit one of the programs in the memory it misses out the g13 or g14 line in auto but shows it in edit mode if I add g13 to the next line showing it takes the whole line off in auto can anyone help please
    regards perry
    Feb 2009
    6028
    You sure your looking at the right page in auto? It should show upper turret on left side of screen, and lower on right.
    Mar 2009
    1982
    the text in auto mode is for single turret in a window only. You can see separate texts for both turrets if you can set two windows in auto mode.
    Edit mode displays full part program.
    Apr 2012
    15
    You never see the G13 or G14 on the program screen.
    Feb 2013
    hi all thanks for all the replies , I ran the program on the okuma and it used the upper turret as I asked so it must read the g13 g14 even if I cannot see it in auto but if I run the old programs in auto I can see the g13 or g14 ,so it must be the way I edit the program if I add a new line should I have the curser on the start or on the end of the last line ?as it seems to push the program up so I cannot see the top lines in auto mode
  1. Okuma 5020L to LCD
    By bapbrm in forum Okuma
    Last Post: 10-01-2012, 12:21 PM
  2. Okuma 5020L to LCD
    By bapbrm in forum Want To Buy...Need help!
    Last Post: 10-01-2012, 03:39 AM
  3. Okuma OSP 5020L
    By BrianM03 in forum Okuma
    Last Post: 04-10-2012, 04:13 PM
  4. With Okuma BL-2 50A and OSP 5020L
    By marfranso in forum Okuma
    Last Post: 06-05-2008, 09:13 AM
  5. Okuma OSP 5020L
    By al-108 in forum Okuma
    Last Post: 03-18-2008, 09:17 PM
