586,796 active members*
2,609 visitors online*
    Mar 2010
    10
    Mitsubishi Meldas 500 alarms on citizen
    just bourght a citizen L32 from 1998.
    it comes with 3 alarms
    EX001 THERMAL RELAY ALARM
    EX101 BAR LOADER ALARM
    EX102 EXTERNAL ALARM 1
    it wont come out of emergency stop
    I tryed do disconnect the hipressure pump but nothing happend.
    theres no power at the bar loader
    Attachment 192444
    theres only light in 1 of 3 lamps here ... is that right??
    what to do ??
    Jun 2004
    511
    EX001 THERMAL RELAY ALARM would be an tripped overload, it is possable that the machine does not turn on the barfeeder untill Estop is cleared. I would check all the overload resets and contacts.
    Nov 2014
    26
    Re: Mitsubishi Meldas 500 alarms on citizen
    The problem with this machine is the EX001 alarm until this is cleared you will have the emergency alarm
    The problem could be the thermal trips these are located at the bottom of the contactors the blue button next to the orange rotary setting for the over load
    Reset by pressing in then power off and on
    Feb 2019
    14
    Hello.. We are looking for parameters of Citizen L20 5-axis CNC Swiss Sliding Head Machine with Mitsubishi Medlas 300 control from 1997.
    Let me know if anyone could provide us with it.. Thanks Regards
    Jul 2019
    53
    Okay, then on the electrical diagrams I see that it can come either from the thermal relays of the pumps, or from the circuit breakers. Circuit breakers and thermal relays must be checked if there is a thermal fault, it must be reset
    May 2003
    130
    Plasto
    Call Citizen tech support, the usually have hard copy backups for each machine and can email them to you at no charge.
    If you dont have any luck there, message me, I have several citizen L20 backups and can see if yours matches.
  1. Replies: 2
    Last Post: 11-05-2014, 12:55 AM
  2. Citizen E32 servo alarms after battery died
    By brainbuktl in forum CNC Swiss Screw Machines
    Last Post: 04-05-2014, 06:27 PM
  3. Alarms on Citizen L20
    By RussellSt in forum CNC Swiss Screw Machines
    Last Post: 07-13-2013, 03:04 AM
  4. meldas m50 alarms
    By jeffea in forum Mitsubishi controls
    Last Post: 03-06-2012, 12:19 AM
  5. Mitsubishi Meldas 520AM Alarms
    By DVF Corp in forum DNC Problems and Solutions
    Last Post: 07-14-2011, 08:34 PM
