Originally Posted by
ksanalytical
I've been searching around and don't see anyone else talking about this so I'm assuming it's my own ignorance here, but i have the worst time getting a profile chamfered with BobCAD v24. I suspect that I'm misunderstanding something in the parameters which is causing dramatically erroneous result. I find myself simulating over and over again until I finally tweak it in. I don't use it much, but on a given part, I probably spend 3 times as long setting up a simple chamfer as every other toolpath combined.
I've attached a pic of the page. I'm using a 0.375" 120 deg mill/drill. The only thing I can find blatantly wrong seems to be the chamfer angle field value vs the diagram. You'd expect to enter 60 degrees based on the diagram but that's definitely wrong. It seems like the program has all the necessary data to do the same trig that I do externally and I can't imagine that they wouldn't have built it to help users avoid the extra hassle.
Base on these parameters and a profile running along the Y axis at X=0 to go to X=-0.0875" and Z=-0.0895" and move straight along the Y axis. Instead, the cutter goes to X=-0.032 Z=-0.177. Am I crazy? Is my trig that bad? Even so, what on earth is the "cutter position" doing anywhere other than X=-0.0875? Incidentally, if I set the "cutter position" to zero, I get a tool path right along the line. If I set it to 0.01, I get a toolpath offset by 0.0169.
I apologize if this has already been gone through. I'm even open to the idea of upgrading to V25 if it sorts any of this out, but it feels like this is something simple.
Best regards,
Ken
