586,129 active members*
2,835 visitors online*
    Jul 2011
    29
    go home wont lift z 1st MAch3 / plasma table
    when I sued to push the go home button in mach, it would lift Z then move X or y, now drags the torch on the metal isntead of lifting it off before moving either x or y - it only happens if I use the go home button, the safe Z height is 1.0" and that works fine while cutting. I'm not sure what changed or why it does this, and cant seem to find it in mach, for some reason I think I ran into this beofre long ago but cant seem to find a note on it anywhere
    any suuggestions (besides remembering to raise z before using go home <g>
    thanks
    4x8 CNC plasma table W/ CandCNC PlaspakIII DTHC, Hypertherm Powermax 1000Gs
    12x36 Lathe, 2hp Alliant 1/12 TMV Mill, Miller 351 water-cooled TIg, various little stuff
    Jun 2004
    6618
    You can edit the button script for that action to lift Z first and then go. The procedure is fairly easy. Just do a search for edit button script here on the zone and you should see it outlined.
    Check out this thread.
    http://www.cnczone.com/forums/mach_s..._x_y_axis.html
    Lee
  1. Garage size home made plasma table build.
    By repauli1 in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 12-18-2014, 04:25 AM
  2. Laser table wont lift up (GCC/ Laser Pro Mercury II)
    By aussiemate in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-30-2014, 01:34 PM
  3. Plasma table in home basement???
    By cmadki4 in forum Waterjet General Topics
    Last Post: 07-13-2012, 03:33 PM
  4. Vertical lift platform-vertical lift table in China
    By mornlifttable in forum News Announcements
    Last Post: 06-28-2012, 04:30 AM
  5. Home made CNC Plasma table help
    By Mick40 in forum Waterjet General Topics
    Last Post: 10-15-2007, 01:56 AM
