Originally Posted by
greggv
Hello, I'd prefer a shop in the Los Angeles area, we have this kind of work occasionally and my last guy with a cnc lathe went nuts. Quantity is 30 pieces, we'll supply the delrin or you can. Contact Gregg at greggv*at*wepackitall*dot*com Thanks
Can you give us some more information, like the tolerances you require. You have all of the dimensions at four decimal points and that generally means + or - .0005", which would be a little ridiculous.
Mike
