586,790 active members*
2,539 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > New machine I designed really want to hear opinions!!
Results 1 to 8 of 8
    Nov 2012
    8
    https://www.dropbox.com/sh/9jxdegko1uimhap/Be3TclxkH_
    Hallo guys, I have just finished a relative BIG project of making a CNC milling machine.
    I would really like to hear some opinions.
    I'm a 32 Mechanical engineer and put a lot of prep work. But the project itself took about 3-4 months to complete. Be happy to answer any questions...
    Jan 2008
    853
    Hi Ben!
    I don't usually download files without knowing what is in them. Could you please post some photos?
    I once thought that my machine was finished ... sigh.
    Paul Rowntree
    Vectric Gadgets, WarpDriver, StandingWave and Topo available at PaulRowntree.weebly.com
    Nov 2012
    8
    Hi, this is not a downloadable file, just a link to a Dropbox page with some pictures..
    Uploading images turn out to be a mess from the ipad, even with dumb tapatalk
    Sent from my iPad using Tapatalk HD
    Jan 2008
    853
    Thanks Ben! Interesting! Can you give some information on your spindle?
    Paul Rowntree
    Nov 2012
    8
    Sure, It is most common in ebay, it cost about 60$
    It rated to turn 12000 rpm
    It has an ER11 collet (max 7mm tool) (which is annoying why not make it 8??)
    I have purchased a set of collets which was in a very low quality (and price)
    The spindle itself comes with a 3mm collet of very high quality
    I Oslo have a PWM driver which cost 15$ in ebay "other" web sites sell the exact same one for much higher price around 50$ )
    And for now I can control the spindle speed via potentiometer (don't know why I can't get PWM from the LPT yet)
    I milled wood and aluminum with no problems, no over heat no nothing.
    I did used a flyer cutter of approx 40mm and the spindle sounds like it would rather be doing something els
    The runout was rated 0.05 mm but I measure 0.2mm on the collet holder!
    Which is sucks I think the spindle motor is ok but the collet holder is poorly done
    Seem like a part I can do myself with better runout
    Feb 2005
    750
    Nice heavy duty machine, could probably handle a much more powerful spindle.
    Halfnutz
    Nov 2012
    8
    No doubt there, I have decided to use a cheaper one as a start since this can be easily replaced, as a start I'm very happy with it, and i learned what to look for in the next one.
    Indeed The machine is 90kg of steel almost no aluminum and is very powerful...
    May 2005
    3920
    Interesting design! Thanks for all of the pics.
  1. machine opinions
    By The Furian in forum Cincinnati CNC
    Last Post: 01-28-2019, 12:42 AM
  2. Opinions wanted on this machine
    By Aegir in forum Uncategorised MetalWorking Machines
    Last Post: 11-21-2013, 07:53 AM
  3. new designed of hotfix rhinestone setting machine
    By machine4rhinest in forum News Announcements
    Last Post: 01-28-2011, 07:28 AM
  4. Best 4 Axis Setup for Taig Lets hear opinions
    By gunlocators in forum Taig Mills / Lathes
    Last Post: 10-03-2008, 12:50 PM
  5. Opinions on First Machine for Newbie
    By jbothell in forum Uncategorised MetalWorking Machines
    Last Post: 03-10-2008, 06:49 PM
