586,347 active members*
3,621 visitors online*
    Apr 2013
    5
    Z axis problem.
    Hi guys i have a problem with my z axis, the machine homes an all axis great but when i try to run a program the z axis only goes down to 6mm which in vetric in progam as the sheet size and the depth of the cut, I thought the problem was the configuration but ive followed all the steps and set the z axis as -100 as my length of travel but it still only goes down the 6mm any help on this would be great.
    Apr 2004
    5740
    It sounds like it thinks it's at the surface and all it needs to do is drop 6mm to be in the material. Are you setting a "floating zero" for the Z axis at the surface of your workpiece? The Home position is just a reference point; the tool tip has to be zeroed in relationship to the workpiece and the CAD model. If the zero point of your model is at the surface of your workpiece, set it there. If it's at the level of the table, set it there instead.
    Andrew Werby
    www.computersculpture.com
    Apr 2013
    5
    Hi i think i have the axis problem sorted now, not quite sure how i did it though.
  1. 4th axis problem
    By RP Designs in forum Centroid CNC Control Products
    Last Post: 12-09-2011, 04:03 PM
  2. a problem with slaved A-axis moving properly relative to Y-axis
    By zool in forum Mach Software (ArtSoft software)
    Last Post: 07-06-2011, 03:45 AM
  3. 760-22 x axis problem
    By tstom in forum Bridgeport / Hardinge Mills
    Last Post: 12-09-2010, 01:37 AM
  4. z axis problem?
    By automatic in forum Open Source CNC Machine Designs
    Last Post: 12-10-2007, 03:04 PM
  5. Z Axis problem
    By studysession in forum Mach Software (ArtSoft software)
    Last Post: 05-06-2007, 12:06 AM
