587,051 active members*
3,733 visitors online*
Results 1 to 3 of 3
    May 2003
    323
    Mazak T1 ballscrew
    Please help/ suggest
    I have a mazak T1
    When I tried to home the z axis the ballscrew came out from the nut
    What can I do
    Feb 2009
    6028
    You mean the nut stripped off the ballscrew shaft? Time for a new screw, once they get that bad, no rebuilding them. I've only ever seen 1 other machine do that.
  1. Mazak MYSTERY. HOW do you clear this ANNOYING Mazak alarm??!!! NOBODY KNOWS!!
    By Mill&Lathe in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-03-2022, 01:55 AM
  2. Mazak QT-10 T2 manuals --acct w/ mazak?
    By CDTINC in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-21-2012, 05:09 AM
  3. Mazak 6pc with machine Mazak 400n
    By anva in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-17-2010, 08:30 AM
  4. Mazak QT-200,Mazak VTC-160A,Mazak FJV-250 all pcb problem
    By sting_dot in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-22-2007, 02:20 AM
  5. Replies: 10
    Last Post: 01-16-2007, 06:27 PM
