Hey all,
Got a question, didn't see this asked before far as I could tell. I've seen this since V24, and now it is an issue with me. Has anyone been able to direct the generated engraving tool path so it makes better sense? Example: I have 20 aluminum blocks on table. I am engraving the inlets for valve ports. (IN, OUT, PILOT, etc.). Blocks are 10 inches apart on Y axis, in 4 vises, 5 per vise. When it goes to engrave the OUT ports, it goes the the first block in vise and engraves the O. Then it goes to the middle block and engraves another O. Then to the right side and engraves an O in word PILOT. Then goes back to first block and does the whole word, second block whole word, etc.
Question is, how does BobCAD figure out where to go and WHY?? Seems easiest to me to just engrave the whole word in order, then move to next word. Usually this hasn't bothered me 'much' as I was doing single words here and there. Now it is being used in production and there's way too much wasted time and travel moving all over the vises doing one letter here and there. I don't see an option of telling it anything as far as start position, etc.
Anyone have this problem and have you been able to fix it? I did report this to Bobcad couple times back in V24, and once in V25. Has not been fixed.
Help?
