586,832 active members*
2,860 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Daewoo Puma 240 rapid override stuck at F0 or 50%
    Jun 2012
    We have a puma 240 with fanuc 18 control.
    Our problem is that the rapids will not go past 50% and while on 50% the led is blinking.
    Can anyone help on why the machine will not go into 100% rapids. I have turned off the tailstock and checked the touch setter inputs for up and down.
    Jun 2004
    511
    Could be that the OP soft key is over ridding. There is an software operator panel under one of the mode keys.
    Feb 2009
    6028
    Door interlock?
    Feb 2013
    788
    Touch setter would cause "no travel" in the direction of the problem, if it were the issue. (so that's probably not it.)
    The fact that, when you have it set to 100% rapid you get a different action than when you have it set at 50% (i.e. flashing switch or non-flashing switch LED...so that's probably not it.)
    The lack of tailstock extended, or at home position could give the same issue you are experiencing, check those switch's inputs for function.
    Is the "Dry Run" switch functioning correctly and in the correct position, as it makes rapids slower.
    If you check those and they are correct, give me the ladder version and I'll look into it further.
    Doosan Service Technician
    [email protected] O:973-618-2461 M:973-803-9479
    Nov 2007
    188
    Every time I have seen this in the past it was switches on the tail stock If I remember right it has always been the switch that shows that the tail stock is clamped
    Aug 2007
    20
    Tail stock. Easy fix, don't bother calling a tech.
  1. Rapid Override?
    By zman300 in forum Fanuc
    Last Post: 02-04-2022, 08:06 PM
  2. Daewoo Puma 240 rapid override stuck at F0 or 50%
    By DHartsell in forum Mori Seiki lathes
    Last Post: 06-21-2013, 03:29 PM
  3. Daewoo Puma 250lb lost rapid
    By jhuddleston in forum Daewoo/Doosan
    Last Post: 07-10-2012, 01:49 AM
  4. Rapid override
    By MSGMachine in forum Haas Mills
    Last Post: 03-28-2011, 01:22 PM
  5. RAPID OVERRIDE
    By CNC_BOB in forum OKK
    Last Post: 06-02-2008, 11:34 AM
